electronic ignition
baz
electronic ignition
#1 PostAuthor: baz » Fri Sep 11, 2009 5:40 pm
hi lads, going to fit electronic ignition to my z1a, is it boyer or dyna ? and will they have them at staff show. cheers baz
FER
Auld Heedyun
#2 PostAuthor: FER » Fri Sep 11, 2009 6:19 pm
Dyna . Get it from Z1 Enterprises .
fer
#3 PostAuthor: Pigford » Fri Sep 11, 2009 7:25 pm
DYNA - every time :wink:
GUYZED
#4 PostAuthor: GUYZED » Fri Sep 11, 2009 11:35 pm
Yep DYNA from me aswell - put it in set it up and forget about it :D
#449
Z1000A2 Z650B1
baz
#5 PostAuthor: baz » Sat Sep 12, 2009 10:17 am
cheers lads, dyna it is then. are they easy to fit.
Russ
Dyna
#6 PostAuthor: Russ » Sat Sep 12, 2009 12:17 pm
Yeh......Dyna is easy as long as your mechanical advance unit is in good nick. Just done mine took about an hour including all the wiring mods I had to do that you won''t have to .
floydsz1
#7 PostAuthor: floydsz1 » Sat Sep 12, 2009 2:54 pm
Hi BAZ
Should take about 30 mins to fit. very simple and nothing to break down as can happen with other ignitions. Basically all you do is remove the points/condensors/timing plate etc and fit the new ignition plate and plug it into the coils.
Like has been said, i got mine from http://www.z1enterprises.com/
though the dollar pound exchange was a lot better then.
this is what i fitted to my Z1A , MAKE SURE YOU GET THE CORRECT ONE FOR YOUR ADVANCE
http://www.z1enterprises.com/detail.aspx?ID=200
simples
Z1b, z900 A4, zxr750 m2, zrx1200
Z1000 (2003) lawson thingy,
Z1000 (2004) z1b lookalike ,
Z1000j lawson race bike,
Gsxr750H.
baz
#8 PostAuthor: baz » Sat Sep 12, 2009 5:27 pm
cheers for that pal
#9 PostAuthor: Pigford » Sat Sep 12, 2009 7:26 pm
I think Chrisu did a "blow-by-blow" guide (with photo's) on here somewhere :wink:
