single sider
- streetfighter z1a
- Regular Poster
single sider
i've got a single sider off a triumph that i want fitted to the zed,now that's not really a problem!.what it's got is a 200 section rear tyre that i would like to keep on,is that were the hassle is going to start.Has it been done before,has anyone got photo's.Your thoughts please.
if in doubt,streetfighter it.
- streetfighter z1a
- Regular Poster
A few of us have 180 section tyres... me, Ginger Bear, Murph... etc.
Having chatted with GB about his recent exploits, a 180 is near the tyre limit coz room runs out between the frame & the tyre alignment
Unless you wanna start hacking & welding the frame section adjacent to the drive sprox
Have a shufty in the projects section.
- streetfighter z1a
- Regular Poster
- streetfighter z1a
- Regular Poster
If you think about widening the frame before yoy start cutting down the arm.
I think you may sort it, a lot of peeps start to cut swinger and run into clearance problems.
My frame is 30mm wider and i have loads of clearance for chain.
Who will be the first with a 300 rear on here? We all love a fat arse don't we.
Baza
Just re read this and went and had a look at my bike, Frame is no problem as it will just need jigging out.But with a 5/8 offset sprocket you will be hiting a 200 rear tyre, so you will need a bigger offset and outrigger bearing to match then sort the carrier out.
Easy, then you can sort the rest out next weekend.
Baza
From my own experience a 5/8 offset sprocket is the widest you can go before the chain hits the frame & a 180 rear tyre is the widest you can go if you want the wheel centrally mounted.
Frame widening would be required to fit anything wider... If you want to do it properly.
Speak to Talon re; offset sprockets. I'm sure they would make one with a larger offset, they made a special for me & Zed1015 (19t) at a reasonable price. Might need an outrigger, or poss use GPZ output shaft & bearings.
Good luck!
Good luck!
The profile of the tyre will make a difference - and I don't mean like 180/55 or 180/70 etc........
I had Batalaxes on the Zed originally... Now got Avon Vipers and they are actually a few mm wider, & me 630 chain just touches the tyre. Not a problem, but now there is slight signs of tyre/chain interface
