Points cam
ted1r
Points cam
#1 PostAuthor: ted1r » Tue Jul 28, 2009 6:49 pm
Does the team think :?: that the heel of the points arm should be just touching the rotor or should there be a gap, I am at a loose end with my timing.
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
BShaw
#2 PostAuthor: BShaw » Tue Jul 28, 2009 7:33 pm
I don't do points Ted but, thats not the important end... open, lift, close. That's the important bit or bits.. If memory servs me right a dwell meter is the way to go
Baza
Garn 1
#3 PostAuthor: Garn 1 » Tue Jul 28, 2009 11:34 pm
Ted, the fibre heel should bear on the cam with some pressure from the curved steel blue spring strap. The points are controlled by the heel bearing on the this cam. If there is no pressure on the cam you will not be able to set the points to the required 0.015" odd! .... No gap ever between heel & cam!
Note: I have found some replacement points of the Z1/ Z900's are hard to set ... something to do with their dimensions ... maybe off a Z650!
RegardZ ~ Garn
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Wed Jul 29, 2009 8:56 am
Echo Garns comments, I've had trouble in the past & found that the points were either Z650 or pattern so there must be a subtle difference.
ted1r
post
#5 PostAuthor: ted1r » Wed Jul 29, 2009 5:08 pm
Thanks but I have a 3mm gap tween points heel and rotor when points closed ,I think the rotors worn, has anyone else come across this b4?
Ted
Z1R D1
Granada
KLE650
tlc
International Rep
#6 PostAuthor: tlc » Wed Jul 29, 2009 5:23 pm
Hmmmmmmmmm.
Rotor steel......................points fibre / resin.
Do the math !
Asphalt Cowboy
steve bowdler
#7 PostAuthor: steve bowdler » Thu Jul 30, 2009 6:14 am
tailiftchris wrote:Hmmmmmmmmm.
Do the math !
Are you trying to say something ?? :lol: :lol:
ted1r
post
#8 PostAuthor: ted1r » Sat Aug 01, 2009 5:33 pm
Lost the plot with this timing, got it set bang on static runnig sweet, just been for a run going great till ,back homme i`ve two of the most beautiful blue down pipes and two normal.put strobe on bang on, plugs perfect colour, HELP :!:
Ted
Z1R D1
Granada
KLE650
hillbilly
#9 PostAuthor: hillbilly » Sat Aug 01, 2009 5:44 pm
sounds like a carb problem,running a bit lean on the blue pipe cylinders.
#10 PostAuthor: Pigford » Sat Aug 01, 2009 5:59 pm
Ted, do yourself a favour & bung on a Dyna S :wink:
