Z-POWER FORK TUBES
ROZZER
#16 PostAuthor: ROZZER » Wed Nov 26, 2008 6:44 pm
Roger, do yer back a favour and lay the frame over the motor when refitting back in the frame. Much easier to do and will have less chance of damaging the nice new powder coating. Of course the other way is to get some mug to lift it for yer!
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
mikey
#17 PostAuthor: mikey » Wed Nov 26, 2008 7:55 pm
Just done it that way with my MK2 and couldnt beleive how easy it was, when i think back over the years how many times ive lifted and heaved engines up and into frames :roll:
Roger Hill
#18 PostAuthor: Roger Hill » Thu Nov 27, 2008 11:09 pm
I have used the frame on engine dodge a few times .I also took the cam cover off as well as that gives you a bit more room to work with .Any how the lump is back in the frame and the main stand is on and its up on its stand.I am waiting for the taper head bearings and roller swing arm bearing kit to turn up so I can get the races fitted and the front forks on with the front wheel in it all gets a lot more stable .I may be teaching you guys how to suck eggs here but I am becoming amazed by how many parts are still available as genuine Kawasaki parts and that some of the prices are not that bad .You can still get the proper cable ties that hold the switch cables to the handle bars and the cable clip that holds the clutch cable to the frame between the exhaust front pipes,headlamp rim screws,foot rest mounting rubbers and the rear brake adjuster to name a few.The top end of the motor had been vapour blasted but the crank cases are original 34 years old .The bike is an import so it has not had good old English salt to contend with so the crank cases are still quite bright after a hot pressure wash.
phil churchett
#19 PostAuthor: phil churchett » Tue Dec 02, 2008 7:04 pm
Here you go roger. Remember this advert? Taken from "BIKE" magazine October 1975.
Roger Hill
#20 PostAuthor: Roger Hill » Tue Dec 02, 2008 11:47 pm
Hells teeth I remember that .What about them groovy clothes .I think I might have to let the trousers out a bit these days .I just ran the bike reg on the DVLA site but it has gone.I reckon the picture was just before I had that UK long rear fender off and stashed behind my tool box .Just think that was so long ago Elton John was straight and Jacko was a black guy .Thanks for digging that out I have not seen it for years it brought back a few memories . It has helped to cheer me up as I have just discovered that I did not send the right hand rear engine mount in for powder coating with the rest of the stuff so I have to go back with it .I have a few extra days off at Christmas so hope to get in the garage and get some work done on the bike .
phil churchett
#21 PostAuthor: phil churchett » Wed Dec 03, 2008 2:15 pm
Davick used to have some great adverts, will have to dig some more out.
