Cleaning carbon from piston crowns and combustion chambers
#1 PostAuthor: PAULJAC47 » Tue Nov 25, 2008 6:22 pm
Hi All just took the head off my Z1B to renew valve guides and seals does anyone know a better way of cleaning carbon from pistons crowns and combustions chambers other than by just scraping with a soft wooden or plastic tool?
#2 PostAuthor: Pigford » Tue Nov 25, 2008 6:49 pm
A bit of elbow grease & soft scraper is best... :|
You could try a 'soft' wire wheel...... :?:
kawamick
#3 PostAuthor: kawamick » Wed Nov 26, 2008 1:19 pm
Oven cleaner works perfect.
Mick
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
MaineKZ
#4 PostAuthor: MaineKZ » Wed Nov 26, 2008 2:30 pm
kawamick wrote:Oven cleaner works perfect.
Mick
Caustic Alkaline Oven Cleaner and Ali!!!! You're living dangerously there.
That stuff will mess with your Ali's surface layer -could be storing up big trouble for the future.
tlc
International Rep
#5 PostAuthor: tlc » Wed Nov 26, 2008 6:25 pm
I would talk to the Debben twins.
They demonstrate time and again that when it comes to engines they know what is what :!:
Asphalt Cowboy
kawamick
#6 PostAuthor: kawamick » Thu Nov 27, 2008 1:21 pm
Mick
You don't need a Alkaline Oven cleaner.Ask your wife for her oven cleaner foam.I'm working with it since years, and had never problems.
Mick
#7 PostAuthor: PAULJAC47 » Thu Nov 27, 2008 6:02 pm
Hi Guys thanks for suggestions have also been told Red X and carefull use of rotary soft brass brush in flexible drive will try out ideas and see if are effective Cheers Paul J..
#8 PostAuthor: PAULJAC47 » Thu Nov 27, 2008 6:02 pm
#9 PostAuthor: PAULJAC47 » Thu Nov 27, 2008 6:02 pm
#10 PostAuthor: Pigford » Thu Nov 27, 2008 6:09 pm
................. once, twice.... nay - thrice :shock:
#11 PostAuthor: PAULJAC47 » Sat Nov 29, 2008 4:45 pm
Red x and soft rotary brass wire brush worked well ,a smear of vaseline around edge of piston stopped any crap going down bores it holds onto carbon when you turn engine over and piston goes down easily wiped out then with clean rag.......
Blue900Z1B
#12 PostAuthor: Blue900Z1B » Mon Dec 01, 2008 10:56 pm
Another way that I have seen working, with my son doing pistons etc in a Toyota V6 engine, is using carb cleaner which comes in aerosols (he got his from Halfords where I have a trade card). Let it soak into the carbon and it comes off relatively easily with gentle rubbing with a cloth.
