Braze or weld?
Cajones13
Braze or weld?
#1 PostAuthor: Cajones13 » Mon Nov 28, 2016 3:23 am
I'm looking to stiffen my mkII frame and noticed that Sanctuary appear to braze rather than weld. Does one method have an advantage over the other, such as less prone to cracking?
12/78 Z1000 A3A frame running 1980 C3 Police
garyd
#2 PostAuthor: garyd » Mon Nov 28, 2016 8:46 am
Braze...as you said, less liable to crack.
Oh...and if the weld isn't done well...could make the joint weaker.
At least with Brazing, the point won't be any less strong if it's badly done.
#3 PostAuthor: zed1015 » Mon Nov 28, 2016 9:44 am
If done correctly weld should not crack, this is usually a result of using too much heat, the wrong method (wrong gas mix) or not normalising the joint afterwards.
It's best to use oxt/acet or tig if you can.
Bronze welding is more flexible and doesn't affect the parent metal so any changes can easily be reversed in the future.
The preferable choice would be Bronze weld.
Cajones13
Thanks!
#4 PostAuthor: Cajones13 » Mon Nov 28, 2016 2:30 pm
Thanks for that. I suspected bronze brazing would be the best option.
VinnyE
#5 PostAuthor: VinnyE » Mon Nov 28, 2016 7:23 pm
Brazing was the method of choice for joining tubes in both cycle and motorcycle frames eg Reynolds 531 tube. Which was ud-sed in racing frames.
