1979 MK 2 ignition CDI.... Plug gap 30 or 40 Thou ?????
johny brando
#1 PostAuthor: johny brando » Fri Apr 08, 2016 8:00 am
Thanks to good info received on here on the Forum, I'm just about to run new BR8EiX Iridium plugs in my 900 which I'm running MK2 Ignition on & there appears to be some confusion within my 2 Clymer manuals...... one say's 30 thou plug gap & the other says 40-44 thou ????? anyone have a genuine MK 2 shop manual to hand ? It'a std UK spec 1979 CDI package & like i said gunna now use Iridum Plugs...they appear to be generically factory gapped @ 30 thou but if thats wrong .....I'll have very carefully re-gap them ....as they look a bit delicate compared to normal plugs ! Cheers.
#2 PostAuthor: zed1015 » Fri Apr 08, 2016 8:39 am
Leave the gaps at 30 thou (0.75mm).
#3 PostAuthor: Pigford » Fri Apr 08, 2016 11:02 am
If you're running Denso Iridium plugs, you can go to 8.0mm... they're real good :twisted:
#4 PostAuthor: chrisu » Fri Apr 08, 2016 5:14 pm
8mm Mark - are you sure..................??
:D
#5 PostAuthor: Pigford » Fri Apr 08, 2016 5:20 pm
chrisu wrote:8mm Mark - are you sure..................??
:D
:oops: No, not sure.... probably 0.8mm :lol:
#6 PostAuthor: zed1015 » Fri Apr 08, 2016 5:55 pm
:D
Just leave them resting on the head and if it drops on to three you can spot the culprit without even stopping :lol:
Gus
#7 PostAuthor: Gus » Fri Apr 08, 2016 6:15 pm
Nice one
Laughed my little botty off :lol:
"Set the GRINDER on it"
johny brando
Re: 1979 MK 2 ignition CDI.... Plug gap 30 or 40 Thou ?????
#8 PostAuthor: johny brando » Fri Apr 08, 2016 9:58 pm
johny brando wrote:Thanks to good info received on here on the Forum, I'm just about to run new BR8EiX Iridium plugs in my 900 which I'm running MK2 Ignition on & there appears to be some confusion within my 2 Clymer manuals...... one say's 30 thou plug gap & the other says 40-44 thou ????? anyone have a genuine MK 2 shop manual to hand ? It'a std UK spec 1979 CDI package & like i said gunna now use Iridum Plugs...they appear to be generically factory gapped @ 30 thou but if thats wrong .....I'll have very carefully re-gap them ....as they look a bit delicate compared to normal plugs ! Cheers.
THANK YOU very much guy's appreciate all the replies !!!! 30 Thou it is then .........yeh 320 might be a Tad over kill !
Users browsing this forum: Google [Bot] and 14 guests
