750 ltd carb confusion
Hi Guys, Can anyone give me a little info regarding what carbs should be on a 750 ltd.  the carbs are mikuni CVs yet when I go on the net for the specs they all say Keihin, how come ? Thanks to all replies, $tevie.
									stephen g mackay
Hmmm, Ok thanks. Mine has Mikuni round slide CVs. Do you know if they were fitted with the same carbs as the Zephyr 750 ?
									stephen g mackay
The reason I'm asking all this is, I'm gonna build a 750 engine for my Zephyr which has an early GPZ lump in it at the moment. Gonna use a ZR7 bottom end which has the primary chain tensioner, gpz ut 750 barrels, head and cams, z550, gpz 550 or zeph 550 six speed gearbox and maybe skim the head a little. Been doing some research and it seems the 34 mm mikunis are pretty well suited to that setup if you can't get 29 mm smoothbores or the likes. Would love FCRs but too dear. So the previous owner of the ltd must have fitted these mikunis at some point. The ltd is I broke some time ago BTW.
									stephen g mackay
Ah, OK thanks. Wonder if the carbs I already have are from that model ? any idea how I would know ? stamps etc ?
									stephen g mackay
Really ? that's brilliant news cos that's exactly what I have. Thanks Z1bman. really appreciate your knowledge, Yeehaw. $tevie.
									stephen g mackay
Spoke too soon. they're 34s. Bummer. Anyone out there with a set of 36s ?
									stephen g mackay
						steve.w wrote:all gpz 750 inc 750 unitrac ran the bst 34mm mikuni carbs as did the 1000 etc but slightly different never heard of 36mm mikunis on a gpz as standard ..34 is the ones fro the job
http://www.motorcyclespecs.co.za/model/ ... p%2082.htm
