Headlight Bulb
- wheelysteve
Headlight Bulb
What is the best H4 (wattage) headlight bulb to fit on a UK spec Z1B without overloading the 40yr old standard electrics?
Cheers Steve
Cheers Steve
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
- wheelysteve
- SVENLEATHER
- mick znone
found this on a quick search, may find a lot more on a longer one
http://z1ownersclub.co.uk/forum/viewtop ... mp+upgrade
Use the original wiring to switch a relay which is fed from a higher rated fuse ,wiring and is capable of handling the extra current,you can then safely fit high output lamps.
Osram 'Night breaker unlimited' are standard fit H4 bulbs - extra output without using more amps.
Halfrauds etc...
As Paul says - the standard 40 year old wiring/switches can be used to operate a relay - micro relays from auto electrical supplies would fit inside the headlamp shell.
http://www.autoelectricsupplies.co.uk/p ... tegory/194
z-fever do a clear 7" headlamp which I am toying with using.
http://www.z-fever.de/ShopNeu/shop/popu ... boscnicsk7
Non original appearance could be a deal breaker!
Halfrauds etc...
- RALPHARAMA
The standard H4 fitment is 55/60watt, which will work fine on your bike providing the wiring's not shagged. If the wiring is knacked then a new loom is not a huge investment from Z Power and they also sell pattern switches. Whilst the switches aren't as good quality as the OEM ones, they are loads better than a shagged out stocker!
I think that the wiring on most Zeds is getting beyond it's sell by date these days and I have rewired dozens of them now. I wouldn't say I can actually do 'em with my eyes shuts, but I'm getting there
Ralph Ferrand
- wheelysteve
