Hi Lads
Z1B any one havesany ideas about tacho drive leaking oil . Changed both seals which did not seem to make any difference . Would you know if l need a new worm drive or the complete unit holder and drive . Thank you , kind regards
John
oil leak from tacho drive
Great ,Thank you for that .
Kind regards John
Kind regards John
I have a similar problem on my Z1b and need to replace.
There were several options here on the forum and just wondered if sorted and if so which route you took john ?
There was a link for seals to the Sansei site although a z650 fibre washer was also advised?
Did you replace the worm drive also from Z power?
cheers
cheers
