Spark
#31 PostAuthor: ZedHead » Tue Mar 31, 2015 4:01 pm
Good luck CDI faults are a pain
#32 PostAuthor: Pigford » Tue Mar 31, 2015 4:03 pm
Bin it & fit a Dyna S :wink:
jez1100r
#33 PostAuthor: jez1100r » Sat Apr 04, 2015 12:25 pm
cdi fixed it came today now running needs carbs set up thank you for help
#34 PostAuthor: ZedHead » Sat Apr 04, 2015 12:41 pm
jez1100r wrote:cdi fixed it came today now running needs carbs set up thank you for help
Nice one :D
weaver
#35 PostAuthor: weaver » Sat Apr 04, 2015 2:25 pm
did you buy the cd1 from z1bman's link?says 1988 gpz1100,unitrak had finished by then hadnt it?
jez1100r
#36 PostAuthor: jez1100r » Sat Apr 04, 2015 8:18 pm
yes i did
#37 PostAuthor: z1bman » Sat Apr 04, 2015 10:21 pm
weaver wrote:did you buy the cd1 from z1bman's link?says 1988 gpz1100,unitrak had finished by then hadnt it?
the part no is correct for a gpz1100 /a1/a2. allthough it will fill the z1100r . the seller has made an error in the listing. the only difference is a slight difference in the full advance of the ignition
jez1100r
#38 PostAuthor: jez1100r » Sun Apr 05, 2015 7:48 am
What effect will that have on my bike ? The number on the top of the cdi i bought is the same as the one that came off mine
weaver
#39 PostAuthor: weaver » Sun Apr 05, 2015 8:42 am
the unitrak seems to have a different part number to the z1100r
#40 PostAuthor: z1bman » Sun Apr 05, 2015 8:50 am
weaver wrote:the unitrak seems to have a different part number to the z1100r
yes it is a different part number but it will still do the job. as already mentioned only difference is the advance is slightly different
