Z1AExhausts
thesaint
Z1AExhausts
#1 PostAuthor: thesaint » Sat Jun 07, 2014 5:22 pm
I have some orig exhausts and have been trying to remove the baffles. They seem a bit stuck to be tight, may be rusted a bit. Been pulling gingerly on the central bar of the baffle, but worried it might snap. Any ideas what I coud do to get them out. Thanks
PJ
#2 PostAuthor: PJ » Sat Jun 07, 2014 6:11 pm
I assume you have sprayed them with wd40 or something like it and left it to soak in?
If not try that first,
You don't say if you removed the retaining screws either?
thesaint
#3 PostAuthor: thesaint » Sat Jun 07, 2014 6:23 pm
Yes, I have srayed wd and removed the retaining bolt. I wondered if there was something I could soak the baffale end of the exhaust in something without damaging the chrome.
#4 PostAuthor: PAULJAC47 » Sat Jun 07, 2014 7:38 pm
Try Red x and petrol mixed.....If the central bar does snap(probably)use a metal rawlbolt inside the baffle with a ring or bar welded to the bolt head nip it up and use to extract out,you a can also weld a length of threaded rod on the end of the rawlbolt and use a large socket as a slide hammer to tapout...does work.....Paul J
thesaint
#5 PostAuthor: thesaint » Sat Jun 07, 2014 8:03 pm
Great stuff. Thanks for that. Been mesmorised by the video clip. Just a bit more needed. :D
#6 PostAuthor: PAULJAC47 » Sat Jun 07, 2014 8:06 pm
A few have been transfixed over the years with her :lol:
#7 PostAuthor: Garry.L » Sat Jun 07, 2014 8:18 pm
thesaint wrote: Been mesmorised by the video clip.
We like Big Tits on here...... that's why we like Paul.
Jay1969
#8 PostAuthor: Jay1969 » Sat Jun 07, 2014 8:51 pm
With exception, Jimmock likes Big Willies :lol:
Garn 1
#9 PostAuthor: Garn 1 » Sat Jun 07, 2014 10:41 pm
Removing baffles from originals can be difficult.
First remove the retaining 6mm bolt, then gently hit the baffle inwards about 5 or so mm.
I usually get a wire/ pot-cleaner type rotary buff, about the same diameter as the baffle outer diameter (about 55mm) and clean paint etc from this inner surface of the pipe. allow some WD400 to penetrate, then pull the 3mm rod.
I often try to set up a type of "weight on a rod" type puller to remove the baffle..... Can't think of the name of these puller devices, where you have a weight sliding on a rod, to apply a vertical force... Same as PaulJac mentioned.
He probably requires the small 3mm bar not to be there!
#10 PostAuthor: PAULJAC47 » Sun Jun 08, 2014 8:21 am
Right on all count Garn,its a slide hammer you are thinking of,down your neck of the wood did it take 400 attempts to get the Wd40 to work?( means water dispersal 40th attempt for those that dont know) :lol:
Enough of your cheek Gary, go back to sorting that rough old thou out :lol:
#11 PostAuthor: Garry.L » Sun Jun 08, 2014 5:53 pm
PAULJAC47 wrote: go back to sorting that rough old thou out :lol:
I know - I must try harder.
Trust you are well Paul?.
#12 PostAuthor: PAULJAC47 » Sun Jun 08, 2014 8:20 pm
Not bad Matey broke down today watching the Red Arrows show off wont mention what bike i was on or who left the lights on :roll:
