My Haynes manual has let me down again!!
VM26SS Throttle slides
Is it an easy task to remove the slides in these Z900 carbs as I want to check the needle positions. Any help appreciated!
Z900-A4 looking like a Z1B!
You just need to remove the carb tops, then the shaft that connects them all together, then they're out.
Be careful undoing the small screws down inside the slide that keep the needle retained, they are soft!
I give them a sharp tap (screwdriver & hammer) and keep the pressure on the screwdriver whilst giving them a sharp twist. Hopefully that'll work for you as well.
