Exhaust Baffles
G
Exhaust Baffles
#1 PostAuthor: G » Mon Oct 14, 2013 6:35 pm
Hi , Can I confirm please that the baffles on orignal 1976 a4 exhaust do come out ? If so any tips for doing it. Have removed bolts but they seem solid ,Cheers g
#2 PostAuthor: PAULJAC47 » Mon Oct 14, 2013 6:44 pm
Try a good soaking with plus gas and Red X,then you can use a rawlbolt to grip inside baffle and if you are careful use as an exractor to draw baffle out!
G
#3 PostAuthor: G » Tue Oct 15, 2013 6:19 am
Thanks again !
Garn 1
#4 PostAuthor: Garn 1 » Tue Oct 15, 2013 9:25 am
G as PaulJac says, use something like a 8mm "lockse0n", with a piece of 8mm threaded rod about 400 mm long with a large washer & bolt on the end and a lump of weight (brass) with 9mm hole thru, to act as a slide hammer.
Regardz
G
#5 PostAuthor: G » Tue Oct 15, 2013 11:39 am
Cheers Garn , very helpful
