No Kick Start
mickey marley
No Kick Start
#1 PostAuthor: mickey marley » Wed Sep 18, 2013 4:14 pm
Hi all,
Apologies but I'm fairly new to bikes and haven't much technical ability so sorry if this sounds like a stupid question.
The kick start on my Z1 has no resistance - it just swings on through.
I have a Sukuki SP370 and it nearly breaks my foot try to kick through.
Any idea what is wrong with the Z1.
Thanks.
#2 PostAuthor: chrisu » Wed Sep 18, 2013 4:16 pm
does it actually turn the engine over or just spin ?
mickey marley
#3 PostAuthor: mickey marley » Wed Sep 18, 2013 4:23 pm
Hi there - it doesn't do anything it just swings through.
I have kicked over 125's with more difficulty.
Thanks.
#4 PostAuthor: chrisu » Wed Sep 18, 2013 4:41 pm
sounds like there is no gear the other end but that's just weird. Yuo'll need to get at the shaft to look by the sounds of it.
the bad news is you can't get the shaft out without splitting the engine.
a winter job - ride it until it gets too cold.
i assume (hope) the electric boot is working fine......
i have some kickstart shafts in my spares boxes.
Streetfighterkz
#5 PostAuthor: Streetfighterkz » Wed Sep 18, 2013 5:20 pm
Make sure you're not holding the clutch lever in and disengaging the plates.
Regards, Doug
mickey marley
#6 PostAuthor: mickey marley » Wed Sep 18, 2013 5:26 pm
Thanks guys - that's great advice and much apprciated.
I'll have a play at the weekend. It may well be me getting used to the bike rather than the bike itself.
I only picked it up last weekend.
Thanks again for your help.
I'm sure I'm going to need heaps more over the coming weeks.
David.
#7 PostAuthor: Pigford » Wed Sep 18, 2013 6:48 pm
As Streetfighterkz says - if the clutch is dis-engaged the kick start won't turn the engine :wink:
garyd
#8 PostAuthor: garyd » Wed Sep 18, 2013 8:56 pm
PS...when I first had my z900 in the 70s I used to win pints down the pup by betting the Brit contingent that I couldn't start the bike by hand with the kick start...it does turn over easily but you should feel the difference on the compression strokes.
Jay1969
#9 PostAuthor: Jay1969 » Wed Sep 18, 2013 9:15 pm
Also, it would be worth checking if the spring may be
worn out or broken :wink:
KeithZ1R
#10 PostAuthor: KeithZ1R » Thu Sep 19, 2013 4:34 pm
If you take the sump plate off and have a look you can see the kickstart gear from underneath
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
