Z1000 ST CARB SETTINGS
london calling
#1 PostAuthor: london calling » Fri Sep 07, 2007 7:22 pm
I'm after the main jet size,float height,etc,etc for a 1981 Z1000ST.
Jack
#2 PostAuthor: Pigford » Fri Sep 07, 2007 7:38 pm
JACK,
No 'ST' data in me Clymer manual, but:
main jet for 1981-2 KZ1000-J (BS34 carb) 127.5
Float height for same 18.6mm.
Don't know if thats any help :?:
london calling
#3 PostAuthor: london calling » Sat Sep 08, 2007 2:08 am
Thanks for that "Kajagoogoo Pigford" but the ST has 28mm slide carbs as per the MK.2 models.
Jack
FLC
#4 PostAuthor: FLC » Tue Sep 25, 2007 2:36 pm
Hi did you manage to get sorted as im looking for float height for my mk11.
thanks Mick.
london calling
#5 PostAuthor: london calling » Tue Sep 25, 2007 9:01 pm
Hi Mick,I've hopefully got some info on the way and if it turns up I'll send it on to you :D
Jack
#6 PostAuthor: chrisu » Tue Sep 25, 2007 9:17 pm
1980 ST (according to my manual)
Vm28ss carbs
110 mains
15 pilot
float height 26mm
hope this helps.
london calling
#7 PostAuthor: london calling » Wed Sep 26, 2007 9:14 am
Thanks for the carb info Chrisu.
Does your workshop manual have the front fork oil capacity for the ST models??
Jack
#8 PostAuthor: chrisu » Wed Sep 26, 2007 9:19 am
yes it does.
oh you want to tell you ? :)
dry 340cc
wet 310cc
oil level 480mm
sae 10w
on 1978 and later forks must be fully extended and no springs in them when measuring oil level.
so say my manual anyway.....................
london calling
#9 PostAuthor: london calling » Wed Sep 26, 2007 9:22 am
Cheers :D
Jack
FLC
#10 PostAuthor: FLC » Wed Sep 26, 2007 2:20 pm
Yes thank you Chrisu,
are these the same carbs as the mk11 then and do you measure from the gasket face to the top of the actual float, mine all measure 24?
anyway thanks again Mick.
#11 PostAuthor: chrisu » Wed Sep 26, 2007 3:23 pm
yup.
main jets are a different size but the rest is the same.
measurement is from top of float to surface face of the carb body.
I made up a tool similar to the special kawasaki one where you measure using a clear tube against the carb body. It screws into the bottom the bowl where the drain plug is.
