Coils heating up ?
Vendetta761
Coils heating up ?
#1 PostAuthor: Vendetta761 » Thu Jul 11, 2013 11:17 am
sorry all, i have tried searching the forum but i cannot find the thread I read recently about someone having trouble with their coils.
My new acquisition from ebay ,VZ-ST, is not starting so I have swapped over carbs from Olive and now the kill swithc which was broken /damaged .
Still no start so thought about swapping the coils from Olive and whilst i was doing this i forgot to turn the ignition off on VZ, 10 mins later, came back to the bike and the coils were hot hot HOT and the battery drained.....
Any ideas ?
Z1000 ST x 3 , Moto Guzzi G5 special ,V11 special.
#2 PostAuthor: z1bman » Thu Jul 11, 2013 11:32 am
you should not leave the ignition in the on position for more than a couple of minutes as to your cost it will overheat the coils + damage the internal windings. bike should be running or turn of the kill switch if you need the ignition on for long periods
Vendetta761
#3 PostAuthor: Vendetta761 » Thu Jul 11, 2013 12:23 pm
Roger that, Thank you !
#4 PostAuthor: Pigford » Thu Jul 11, 2013 3:05 pm
Old kawasaki kill switches can be a real PITA - they short out for a pastime :??
Taffus
#5 PostAuthor: Taffus » Thu Jul 11, 2013 5:46 pm
Pigford wrote:Old kawasaki kill switches can be a real PITA - they short out for a pastime :??
er that's their job Mark, they provide the earth for the ignition system, you break the path to earth to kill the engine :roll:
(\__/)
(")_(")Image
Garn 1
#6 PostAuthor: Garn 1 » Thu Jul 11, 2013 10:55 pm
Fill up battery and recharge. Coils should survive a bit of over heat. If you have contact points they will need attention.
#7 PostAuthor: Pigford » Fri Jul 12, 2013 7:47 am
Very droll :| Only good if you have full control over that action :shock: The inner workings tend to corrode & short over time :!:
