cometic head gasket
PETER KZ1A
cometic head gasket
#1 PostAuthor: PETER KZ1A » Mon Jul 01, 2013 10:02 am
Does the C8018 cometic head gasket suit a standard bore 900 Thanks
RGH
#2 PostAuthor: RGH » Mon Jul 01, 2013 10:12 am
Garn 1
#3 PostAuthor: Garn 1 » Mon Jul 01, 2013 12:50 pm
I can't understand "Cosmetic" covering 900 thru to 1075 with the one gasket.
There is a difference in the size of the bore hole in the 900 and the 1000 gaskets.
I think there is a chance of the 900 gasket being exposed to combustion if fitted to the larger bore. Conversely, when the 1000 gasket is fitted to the 900, you must be sacrificing sealing area!.
RGH
Re: cometic head gasket
#4 PostAuthor: RGH » Mon Jul 01, 2013 1:16 pm
PETER KZ1A wrote:Does the C8018 cometic head gasket suit a standard bore 900 Thanks
No.
http://www.powersportjunkie.com/COMETIC ... -c8018.htm
PETER KZ1A
#5 PostAuthor: PETER KZ1A » Tue Jul 02, 2013 4:24 am
Thanks for information,the 1 piece gasket is on it's way from Z power :D
