z1000j wont rev up
marve114
z1000j wont rev up
#1 PostAuthor: marve114 » Tue May 21, 2013 8:08 pm
standard engine with standard carbs has k&n filters plus harris with comp baffle. the main jets are 150 neddle set in middle seating only seems to rev up when choke pulled out then revs shoot up any ideas
ps have had the carbs apart and cleaned out all jets with carb cleaner and air line
should have said sorry these carbs were setting in my shed and were cleaned out before fitting to the bike
kawasakichris
#2 PostAuthor: kawasakichris » Tue May 21, 2013 8:16 pm
check for blocked pilots
Fred the Zed
What's different?
#3 PostAuthor: Fred the Zed » Tue May 21, 2013 8:21 pm
Have you changed anything since the bike last ran correctly?
Has it been standing for an extended period?
If nothing has been changed and the bike has been standing, my money is on the carbs being gummed up or rusty fuel blocking the jets and making it run very lean. (Using the choke will restrict the amount of air going through the carbs and compensate for the lean mixture to a degree but it wont rev out freely)
Try that and see how you get on
Fred
Paid Up Member
Mark Tiller
#4 PostAuthor: Mark Tiller » Wed May 22, 2013 8:29 am
CV carbs? Diaphragms split?
Is Vic There
#5 PostAuthor: Is Vic There » Wed May 22, 2013 9:22 am
I had the same and stripped the carbs again and put a wire from a wire brush down the jets, solved the problem, I did blow them with an air line prior to this.
Vic
marve114
#6 PostAuthor: marve114 » Wed May 22, 2013 8:04 pm
thaNKS GUYS FOR ALL THE INPUT it now runs a lot better i think it was partly blocked pilot jets thanks again
marve114
#7 PostAuthor: marve114 » Wed May 22, 2013 8:06 pm
THANKS GUYS FOR ALL THE INPUT it now runs a lot better i think it was partly blocked pilot jets thanks again
phil le brocq
#8 PostAuthor: phil le brocq » Sat May 25, 2013 4:33 pm
I've just fitted a Dyno jet stage 3 kit to my J carbs via M&P, mains are 138 with their own needles, well worth the investment.
Phil.
Users browsing this forum: Google [Bot] and 16 guests
