Reg/Rectifier
Reg/Rectifier
#1 PostAuthor: Pigford » Thu Jun 21, 2007 7:51 pm
I got a Shindengen Reg/Rect, model SH 221-12 0.1.
Its got 4 x wires;
Yellow
Black
Yellow
White/Red
Anyone know if its any good for me Z1000 1978 :?:
debben1
#2 PostAuthor: debben1 » Fri Jun 22, 2007 1:54 pm
Hello Pigford, dont think thats going to be much use, I think you need a regulator rectofier which you can conect 3 yellow wires to from the generator, then the red/white to conect to the battery, black to earth and brown to switched 12v, but I could be wrong. :|
greenlaningxt
Reg /Rect
#3 PostAuthor: greenlaningxt » Fri Jun 22, 2007 3:05 pm
I agree, think you need at least 5 wires, 3 to the stator (yellow) 1 to switched live, 1 to earth.
I put one from a newish GSXR on mine, charging with no problems, did amost the same thing on a GSX I have.
If you read some of the charging problem items around on the web, the way Kawasaki (and others) have the extra wire wired for load means there is extra power knocking around that helps to burn it all out and the battery is not getting full charge all the time.
Its alright on bikes with the lights on all the time, then all 3 windings are beiing used.
Harris Z1000, Several other Road, Off Road and Trials Bikes, Delica Exceed
http://www.greenlaning.co.nr
#4 PostAuthor: Rich » Fri Jun 22, 2007 4:02 pm
Anyone know if its any good for me Z1000 1978 -------No
Go here if you want colour code info for different RRs, download the PDF
http://www.electrosport.com/electrospor ... nding.html
#5 PostAuthor: Pigford » Fri Jun 22, 2007 7:01 pm
Cheers everyone :!:
Oh well, have to eBay it then :wink:
I've copied the pdf fault finder too, thanx Rich :D
