z1a poor compression, time for a rebore
hi guys,trying to find nos pistons & rings for my z1a, z1 enterprises have them not overly keen on buying from us,import taxes vat,and iffy delivery service is a worry anywhere else i can try?What"s opinion on repros from zpower,cheers
I guess from your title you want oversize pistons/rings. If not I have a complete set of standard rings that have only done 100 miles. I found that my bores were at maximum tollerance so needed a rebore. There's some used pistons which I was told by S.E.P were close to minimum tollerance so I replaced these as well. Any good to you ?
I got new pistons and rings from z1 enterprises. They arrived within 7 days and no problems with customs etc.
yes bores checked by zlbman,they were out of tolerance,also confirmed by leakdown test,valves checked too,they were ok.bike has done 43000 on original standard size pistons.Been f---n about for last 6months thinking erratic tickover was carb problem.even with low compression on 2&3 bike seemed okayish at speed,can"t wait to see difference after rebore.
