Where do you guys with the Z1000Hs get an air filter from....without paying £50 for some 30 year old peice of tat.
Is there a modern equivalent or a K&N that will fit?
Cheers for any help.
Z1000H air filter?
if you check your standard filter dimensions with this K&n which is for a Kawasaki h1 500 triple you could probably get this to fit with with some thought
http://www.knfilters.com/search/product ... od=KA-1000
Thanks.
That looks like I'd have to dispense with the origional filter housing, but that wouldn't be an issue.
The K&N site is useful as it gives dimentions.
Will have a measure in the morning to see if this will fit the origional housing...
http://www.knfilters.com/search/product ... od=KA-1700
these guys will sell you one - just don't know how much they are......
http://www.redlinecycle.com/Fuel%20Injection.html
Z1000H air filter?
I'm sure that Z Power can still supply a new fuel valve for the fuel tank.
HARRY
HARRY
