Z1000H air filter?
garyd
Z1000H air filter?
#1 PostAuthor: garyd » Fri Dec 23, 2011 7:01 pm
Where do you guys with the Z1000Hs get an air filter from....without paying £50 for some 30 year old peice of tat.
Is there a modern equivalent or a K&N that will fit?
Cheers for any help.
#2 PostAuthor: z1bman » Fri Dec 23, 2011 8:47 pm
if you check your standard filter dimensions with this K&n which is for a Kawasaki h1 500 triple you could probably get this to fit with with some thought
http://www.knfilters.com/search/product ... od=KA-1000
garyd
#3 PostAuthor: garyd » Fri Dec 23, 2011 9:55 pm
Thanks.
That looks like I'd have to dispense with the origional filter housing, but that wouldn't be an issue.
The K&N site is useful as it gives dimentions.
Will have a measure in the morning to see if this will fit the origional housing...
http://www.knfilters.com/search/product ... od=KA-1700
#4 PostAuthor: chrisu » Sat Dec 24, 2011 9:55 am
these guys will sell you one - just don't know how much they are......
http://www.redlinecycle.com/Fuel%20Injection.html
garyd
#5 PostAuthor: garyd » Sat Dec 24, 2011 10:44 am
Cheers..
That's particularly handy as I need a fuel tank valve as well.
HARRY4448
Z1000H air filter?
#6 PostAuthor: HARRY4448 » Sat Dec 24, 2011 6:22 pm
I'm sure that Z Power can still supply a new fuel valve for the fuel tank.
HARRY
