Starter Relay
HowieD
Starter Relay
#1 PostAuthor: HowieD » Fri Aug 12, 2011 10:58 am
Hello,
does anyone know the Current Draw of a Z1-R Starter Motor? I'm looking for a more compact replacement Relay or use the built in one in an M-Unit (40A).
Mine is all painted so can't see any markings on it.
regards
Howie
CD185, Maggot, Z1-R, Horace
#2 PostAuthor: z1bman » Fri Aug 12, 2011 10:29 pm
why are you looking for a more compact relay. even the most modern relays are as big in dimensions as the z1r?
HowieD
#3 PostAuthor: HowieD » Fri Aug 12, 2011 10:45 pm
I don't wish to replace the Standard Kawasaki one as such but this thing shown below has a built in Starter relay which can take up to 30A and if the Starter Draw is less than that - well, bye bye relay.
These are just some random pics from the www - real pics when I receive it and fit it.
see here for more details of Horace:
http://z1ownersclub.co.uk/forum/viewtopic.php?t=3841
regards
H
#4 PostAuthor: z1bman » Fri Aug 12, 2011 11:00 pm
i am sure i have seen this set up on a previous post . have a look on the project's index. personally i would think this is more than enough to do the job you are looking for
HowieD
#5 PostAuthor: HowieD » Sat Aug 13, 2011 8:03 am
Aye this is where I first heard about them:
http://z1ownersclub.co.uk/forum/viewtop ... motogadget
a bit of w3 research and one is going by DHL as we speak.
H
#6 PostAuthor: Rich » Sat Aug 13, 2011 8:22 am
I would say 30A wouldn't be big enough, You need to check the CCA of your battery, my Yuasa is 230A CCA, I use a Fireblade starter relay, small, built in fuse, rubber mounting and cheap from autojumbles :D
#7 PostAuthor: z1bman » Sat Aug 13, 2011 3:38 pm
are you sure that this unit has a built in relay for the starter? i have looked at various wiring diagrams for this + it shows a separate relay if you expand the photo of the Suzuki that the unit is fitted to you will see the the starter wires are not connected to the unit
HowieD
#8 PostAuthor: HowieD » Sun Aug 14, 2011 11:49 am
Hi,
I was looking to before I bought it but this diagram out of the manual shows some options:
also recommended SWG sizes & Current limits:
It has overload protection built in so I'll try it and see. Failing that I get hold of a Loop Ammeter and see just what the current draw is.
regards
Howie
HowieD
#9 PostAuthor: HowieD » Sun Aug 14, 2011 11:53 am
Rich wrote:I use a Fireblade starter relay, small, built in fuse, rubber mounting and cheap from autojumbles :D
do you know the fuse which is fitted ?
HowieD
#10 PostAuthor: HowieD » Sat Aug 20, 2011 11:18 am
Just for info - I connected the Starter Motor directly to the M-unit and it flashes with an Over Current Fault. Meaning there is more than 40A draw on the curcuit.
So the original is now wired in instead.
regards
Howie
