Coil 1&4 Ohms 3.5 ohm's cold 3.6 ohm's hot
secondary test 14.7 cold when heated 15.6
Coils 3&2 3.5 ohm's cold 3.7 ohm's hot
Secondary test 14.6 cold when hot 15.7
I know her blow drier don't get that hot so i am thinking this coils are bad
Rich wrote:To be honest I don't think it will be the coils.
Please explain this better:
"It will idle but you go to give it gas just drops dead" does that mean it won't rev or cuts out and you have to restart? If the latter does it restart quickly?
Yep i have the Dyna -s pickups but they check out fine thank Godsteve bowdler wrote:This sounds exact same prob I had , did you say you had Dyna s if so go back to points and try it
You can hear mine over any radio station stainless steel wires and non resister plugszorded wrote:Mine was similar to this after i did a silly thing with the wiring and split one of the Green coils completely in half and it killed one of the Dyna pickups too.
The coil was obvious but the telling thing with the pickup was white goo pouring out the back.
I put a borrowed Dyna plate and pickups on it and it instantly cured it.
1980 is very old for those coils!!
If you want to listen to it 'running out of sparks' tune the radio in and move the ariel close to the bike.
Cant remember the frequency but from memory about 95 or so on FM i think.
Very telling.
Blackfox wrote:Yep i have the Dyna -s pickups but they check out fine thank Godsteve bowdler wrote:This sounds exact same prob I had , did you say you had Dyna s if so go back to points and try it
I did find my stock coils in a box and the old point's set up in the basement
the end caps are missing i did find two of them
