Battery Size?
Battery Size?
I'm after a small battery that I can hide away under the tail unit of my Z1R. Does anyone know what the lowest amp-hour rating you can get away with running a Zed. The only ancilliarys I'm using is the lights and a horn. All the indicators and associated gubbins have been removed. The only major draw on the battery will be the starter motor. I am quite happy to have a bit of a reduction in power on the starter because at the moment it will turn over for ages without seeming to loose any go. If it dosen't go on the starter then I don't mind having to use the kickstart! Ta in advance, Ben.
Ginger Bear wrote:Ben, I don't know about the smallest size you could get away with, but I would consider a Gel filled battery. I believe it's safe to mount these on thier side. This may help you fit a larger battery in the space you have.
Yeah I've been having a scout about on ebay and through a few electrical suppliers catalogues and I think I'll take a punt on a 10Ah one. It should fit under the tail unit pretty easy and should still give me plenty of power for the electrics. I'll let you know how I get on!
Right after yet another postage debacle I got the battery and it works fine. Turned the motor over for a minute constantly and was still showing 12.42v on my cheapo multimeter after that so should be fine I reckon, could probably get away with a 7Ah too I reckon as long as the bike starts pretty easily. Due to a schoolboy error on my behalf it won't fit behind the tail light like I wanted so I've decided to do the job properly and remove the starter motor and just have a kickstart only which will allow me to run a really really small battery which will definitely fit. That'll teach to measure twice and all that malarky
