43mm brake piston
43mm brake piston
Recently purchased a 43mm piston for my z1b 1975 the one i have been supplied is 43mm diameter but is longer than the one i removed this is 34mm long the new one is 41mm long any ideas what this longer one may be for?
PaulJac, I'm sure I measured the OD as 43 mm (will check that later!).
Anyway, you may find with longer piston, that you have trouble fitting new pads.
Incidently, I purchased a piston from a brake place, it was exactly the same, except it was 3 mm shorter. I figure it would work, however, I may be in trouble when the pads wear. The piston was from the car, a Lexan dual pot caliper (a lot cheaper than the Kawasaki replacement).
Thanks for that Garn1 sure they are 42mm you say you used ones from a Lexan is that a Ford Model? have you the part number? Cheers Paul J..
PaulJac, the nominal size outside diameter of the Z1 series brake pistons is 43 mm (I checked a few). The replacement piston I purchased, which was about 3 mm shorter, was from a company "Protex" with numbers on box...090P0180 and A11R2H. I was told they were from a model of the up-market Japanese car "Lexus" (not Lexan, as previously stated). There is also a well priced replacement from USA.. Z1 Enterprises.
RegardZ
RegardZ
PaulJac or anyone, there was no mention that the outside diameter of the piston for the Z1B was initially misquoted, or indeed, was correct.
I make it 43 mm, the question talks of a 42mm piston........ I don't mind being wrong! It just needs qualifying for the other innocent readers.
