Bike Chain Info
Bike Chain Info
#1 PostAuthor: Pigford » Thu Sep 24, 2009 8:20 pm
Might be a good read before you buy your next C&S set :!:
http://www.quality-cycle.com/truth_abou ... chains.htm
KeithZ1R
#2 PostAuthor: KeithZ1R » Thu Sep 24, 2009 9:01 pm
Well you live and learn ..... and Ive just learnt a bit more :) :!:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
martinz1b
Re: Bike Chain Info
#3 PostAuthor: martinz1b » Fri Sep 25, 2009 9:07 am
Pigford wrote:Might be a good read before you buy your next C&S set :!:
Thanks Pigford.
Very interesting, I bought a cheaper chain (Heavy Duty non ring) because the mileage I would be doing on my bike when it is finished would be minimal. It is an Iris 630RX and it has a tensile strength of 9240lbs so is nearly at the top end of the guide. That article has changed my mind about ever getting an overly expensive (overpriced) chain again.
simon gilling
#4 PostAuthor: simon gilling » Sat Sep 26, 2009 3:09 pm
thanks for this info,
I wanted 'x' ring chain on my Z1 in 2000, found that 630 pitch was only in available in 'O' ring at best. So I fitted an 530 gearbox sprocket (17 tooth) from a VN800 and got B&C to make up a 38 tooth rear sprocket, finished off with a D.I.D. chain. It has run well for many years, no real wear, smoother and lighter.
I have some info for compatible 530 pitch sprockets from Z1 to 1000J including offsets, all available 'over the counter'.
Maybe the nudge I need to write a fresh report, there is also a really good site at jtssprockets.com where you can check the specs. of your existing gear shaft splines etc. and check out alternatives.
By the way although I agree that you should lube a chain from the inside of the links, I wouldn't like lube on my tyre, like in the picture.
Simon
p.s. I am sure that I read in the latest magasine that Will (Saxon Turbo) used a 19 tooth 530 gear box sprocket, I'd like to know if he had to mod anything to fit it.
p.p.s.
I read somewhere that you should always choose sprockets teeth numbers to avoid the chain pitches always running over the same sprocket teeth.
Don't ask me, I just got here myself!
02GF74
#5 PostAuthor: 02GF74 » Mon Sep 28, 2009 9:03 pm
We’ll be adding more interesting facts in the near Future!!
can't wait ..... :o
Andy230262
#6 PostAuthor: Andy230262 » Tue Sep 29, 2009 1:31 pm
I am new to all this. So what chain and sprockets would i be best to buy for my KZ1000 A2? Where would i get them from?
I only do A few thousand miles a year.
Now have a KZ1000 A2. I love it
Geoff Meager
#7 PostAuthor: Geoff Meager » Wed Sep 30, 2009 10:49 am
Learn't something new there ..... cheers Mark
BShaw
#8 PostAuthor: BShaw » Wed Sep 30, 2009 7:22 pm
Cheers Piggy interesting init, I borrowed it BTW hope you don't mind.
Baza
