J motor in a 78 Z1r frame?
galaxian
Wil the J motor not bolt into a Z1r frame for some reason? I thought its a straight fit.Any help would be great.
- london calling
- paul doran
galaxian
Drop the J motor in the z1r frame by the rear upper mount and space accordingly. You'll need to make some front engine plates and do away with the bottom mounts on the frame as the J doesn't use them. It's a swap thats been succesfully done 100's of times and should be a simple job for you judging by the work you've done on your streetfighter.
- london calling
- paul doran
