J motor in a 78 Z1r frame?
galaxian
#1 PostAuthor: galaxian » Tue Aug 25, 2009 12:59 pm
Wil the J motor not bolt into a Z1r frame for some reason? I thought its a straight fit.Any help would be great.
#2 PostAuthor: zed1015 » Tue Aug 25, 2009 4:57 pm
Yes the J motor will more or less bolt straight in.
london calling
#3 PostAuthor: london calling » Tue Aug 25, 2009 5:47 pm
The J motor has 2 mountings at the front and 1 at the rear.
The Z1R will have 1 at the front and 2 at the back.
Jack
#4 PostAuthor: paul doran » Tue Aug 25, 2009 7:02 pm
You will need major modification to make it fit
so no it won't bolt straight in
galaxian
#5 PostAuthor: galaxian » Tue Aug 25, 2009 9:11 pm
Ok, is the Z1r frame similiar to a 77 kz1000a, where the J motor will not fit without mods as well?
There is a cheap J motor for sale locally and all i have is a spare Z1R or 77 kz1000 frame.
#6 PostAuthor: zed1015 » Tue Aug 25, 2009 10:07 pm
Drop the J motor in the z1r frame by the rear upper mount and space accordingly. You'll need to make some front engine plates and do away with the bottom mounts on the frame as the J doesn't use them. It's a swap thats been succesfully done 100's of times and should be a simple job for you judging by the work you've done on your streetfighter.
Keefleaf
#7 PostAuthor: Keefleaf » Tue Aug 25, 2009 10:48 pm
I put a J motor in a Z1000 frame,[`77] and had to cut off the lower rear engine mounts `cos a J motor is "deeper" at the back.
As said above ,new front lower bar/engine mount at front.
galaxian
#8 PostAuthor: galaxian » Wed Aug 26, 2009 12:57 pm
Thank you all for the information. I am to to see a man about a J motor.
london calling
#9 PostAuthor: london calling » Wed Aug 26, 2009 4:08 pm
Get a J frame as they is the bestest :wink: :D
Jack
#10 PostAuthor: paul doran » Wed Aug 26, 2009 6:18 pm
hmm! I know where there be one :lol: :lol: :lol: :lol: :lol:
