Electrical Kill Switch Help
Gus
#16 PostAuthor: Gus » Tue Aug 04, 2009 4:04 pm
Cut the blue/white wire! Cut the blue/white wire!.............. NO! NO! the pink one............... NO! the black one. . ............ . OOOOOOOPS :boom
"Set the GRINDER on it"
Taffus
#17 PostAuthor: Taffus » Tue Aug 04, 2009 7:33 pm
This is from the diagram supplied, e&oe .Join the 2 black wires as this will complete the circuit for the starter motor solenoid.
Leave the other wires disconnected as this allows the coils to be earthed and will stop the engine if both the clutch is not pulled in and the side stand is down.
Leaving them disconnected stops you needing to pull the clutch in to start but will allow you start in gear so be careful! You could join them and pull the clutch in to start.......I hate that though its a pain in the arse.
(\__/)
(")_(")Image
Royalratch
#18 PostAuthor: Royalratch » Tue Aug 04, 2009 8:26 pm
Joined Blacks and it starts!
Leave the colours disconnected to deactivate ignition kill.
I'm on the move!
#19 PostAuthor: Ginger Bear » Tue Aug 04, 2009 8:28 pm
Thank goodness for that!
Some of us were getting worried :shock:
Royalratch
#20 PostAuthor: Royalratch » Tue Aug 04, 2009 8:47 pm
Cheers gang - gave it a bit of a detail too so will post some nicer pix.
:D
