I've always gone for static timing..... coz I can't afford a decent strobe
Denso spark plug probs
You got any Rizlas Piggy i need to measure the exact point of opening of my points.
There is a time constant for sufficient voltage to build, required to 'fire' the plug. The constant is determined on inductance/resistance, and includes the entire circuit. Rather than a timing light, you could use a current transformer and read the voltage and current on a dual trace scope. As mentioned, you are looking for consistency across cylinders, noting the voltage levels required to commence current flow. Variations in voltage will translate via the time constant, into degree variation. A variation over the speed range could imply gap resistance, whereas a consistent, but different voltage level compared cyl to cyl could imply a circuit problem.
http://www.eng-tips.com/viewthread.cfm? ... 561&page=3
cra-z1
