I am looking to replace the two rubber inserts on the ends of a steering damper. They are only round rubber with a steel insert tube. I am unsure of the manufacturer of the steering damper. Anyone know of a supplier.
Cheers Jumbo
Steering Damper Parts - Steering Damper Parts
- london calling
Hi Jumbo if it is a Kawasaki type steering damper,7 way adjustable i'm pretty sure they are un-servicable but i'm not 100% sure.The White Power,Ohlins,etc are re-buildable.
If you speak to Dave or Phil at Z-POWER,tel 01942 262864 they should be able to tell you if it's possible to repair your damper.
