torque wrench.
mick znone
torque wrench.
#1 PostAuthor: mick znone » Thu Jul 23, 2009 6:14 pm
advice needed guys, im replacing the cam cover gasket tomorrow, i understand the 16 bolts need to be tightened to 104 in-lb, i have bought a torque wrench which ranges from 28-210 newton metres, i take it i have the wrong wrench :? or can it be converted :?: ive never torqued anything. :press
Gus
#2 PostAuthor: Gus » Thu Jul 23, 2009 6:28 pm
It can be converted
http://www.onlineconversion.com/torque.htm
104 lb-inch = 11.75 Newton metres
Unfortunately the range of your torque wrench is too high.
"Set the GRINDER on it"
#3 PostAuthor: chrisu » Thu Jul 23, 2009 6:39 pm
which is why saddos like me have 3 torque wrenches......
mick znone
#4 PostAuthor: mick znone » Thu Jul 23, 2009 7:04 pm
many thanks Gus, will take wrench back, it starts at 25, blummin rubbish.
i will try the light pinch up of each bolt method, in sequence
m1ks
#5 PostAuthor: m1ks » Thu Jul 23, 2009 8:04 pm
With something like the cam cover tightening by hand is fine, just make sure you don't confuse in-lb with ft-lb :)
There are usually a few low torque critical bits in an engine which i'd always use a wrench for but most lightweight ones are ok with a good application of common sense, make sure mating surfaces are spotless and nip up sequentially in a clockwise from centre manner like a head bolt set.
Ironically you find the low range torque wrenches are the costlier ones, Halfords used to do decent ones for £50-ish each which isn't bad.
your generic Argos £15 50-150ft-lb wrenches are fine for general maintenence use, i have one of these and a precision accurate small un. If I were ever into professional racing builds then a set of three minimum top quality ones would be the order of the day.
zeroed
#6 PostAuthor: zeroed » Thu Jul 23, 2009 8:26 pm
£25 Draper :oops: very well made and good enuf for me!
toycollector10
#7 PostAuthor: toycollector10 » Thu Jul 23, 2009 11:54 pm
I've got "Cylinder Head Cover Bolts" 70 in-lbs or 0.8 kg-m stated in my Shop Manual.
Last edited by toycollector10 on Fri Jul 24, 2009 1:39 am, edited 1 time in total.
BShaw
#8 PostAuthor: BShaw » Fri Jul 24, 2009 12:52 am
Mick, a normal 10mm spanner and two fingers should do it, that's why spanners are the size they are. I use a bit of silicone as well ( but that's just my opinion) you should have a van full of clear !!
Baza
