its the left hand outside rear thread on the head. the relay guy said it can be done in situ.Hello Guest User,
block thread gone
- mick znone
block thread gone
while im putting a new gasket in, i think i will helicoil this thread. the cover is held down with 16 bollts, the rear outside one has been drilled out through the head, a bolt goes through and a nut goes on the end. i believe this can be done in situ, with the tank off, AM I RIGHT GUYS
its the left hand outside rear thread on the head. the relay guy said it can be done in situ.I DONT CARE, IN OR OUT BUT IM ENJOYING THE DEBATE......................ARMSTRONG MT500. a pushbike, waves.....addict, no offence
Steve Cooke
- mick znone
wilsonsjw11
