Dyna Green Coils
Dyna Green Coils
Where's the best place to get these DC1-1 (3 Ohm-green)? or is there an alternative?
Lost in the desert somewhere
bigmac103 wrote:tried ebay for the green 3 ohms no joy, what are the grey ones? can I use them with the Dyna S points?
DYNA S - Points..... a contradiction in terms
Yes, 2.2 or 3.0 ohms are OK with Dyna S.... Make sure you only use proper leads.... DYNA leads are best coz they are designed to work with the whole DYNA set up... SOme lead/plug caps can cause problems...
