Tacho Restoration
duckman
Tacho Restoration
I've just taken my clocks apart for restoration. The damping is OK so I just need to clean up the visuals. The glasses are dirty and pitted on the inside (how does this happen?) but they will clean up OK. My question is about the tacho redline area which is well faded. Is this a decal? If so does anyone know where I can get one. If this is not possible I'll have to carefully paint over the red parts. Anyone done this that can give some tips. TIA
- mick znone
you can buy the red line kit off eBay, or you can buy the whole face. regarding the glass, is it possible that they have been repaired before and whoever did it turned the glass around, this could explain the damping being ok.
- mick znone
http://cgi.ebay.co.uk/Kawasaki-Z1-Z1A-Z ... 1|294%3A50
there you go mate.
there you go mate.
- mick znone
Steve Cooke
I opted to restore my own clocks as I couldn't bring myself to pay £300 odd and it's not that difficult, I stripped cleaned and lubricated the internals, cleaned the faces and very carefully touched in the redline using an indelible illuminous red marker and a magnifying glass, it 's also possible to re-polish the glass if they're not too bad, failing that just get new ones cut.
I also chose to retain the original mileage on the clocks and noted the mileage at rebuild, it really bugs me when the clocks are zeroed as I find that pretty naff and phoney.
Steve Cooke
Steve, I didn't need to renew the damping as my clock needles where stable, although I doubt that it would be too difficult as it's just a case of finding a fluid of the correct specific gravity, I would have tried one, tested and tried again until it was right. I set my clocks on a bench so I could run them using a variable speed drill and introduced vibration to simulate riding conditions.
- mick znone
i took a spare tacho apart Steve, not difficult, there was no gasket.Steve R wrote:I think it is a bit of a problem getting the correct damping fluid from reading other forums.
I need to take mine apart to clean the back of the glass, is it very difficult getting the ring that clamps them together apart? Is there a gasket there that needs replacing?
