Clutch adjuster cover
Robw
#1 PostAuthor: Robw » Sun May 17, 2009 8:19 pm
I am having problems getting the little cover off on the engine sprocket cover, so that I can adjust the clutch. Has anybody had a similar problem and how did you sort it.
Cheers Rob
tlc
International Rep
#2 PostAuthor: tlc » Sun May 17, 2009 8:21 pm
WD40 and a wiggle !
Asphalt Cowboy
#3 PostAuthor: Pigford » Sun May 17, 2009 8:21 pm
Try taking the whole sprocket cover off & have a closer look.... :wink:
gray
#4 PostAuthor: gray » Sun May 17, 2009 8:36 pm
It can be difficult to remove , there's nowhere to grip .
If it's not corroded in place , a flat blade screwdriver into one or other of the boltholes and sideways force dislodges it . Otherwise it's like Pigford says , remove the sprocket cover and tap it out from behind .Reassamble with grease! It might be decades of salt :( or Solvol Autosol :)
Gray
gray
Robw
#5 PostAuthor: Robw » Sun May 17, 2009 8:36 pm
Piggy, I know there are 2 screws holding it on, but it does not move even when these are out. Is there something else I am missing.
Rob
#6 PostAuthor: Al » Sun May 17, 2009 8:48 pm
Theres nothing behind that cover but a 12mm half nut and an adjuster screw.
taking the whole outer cover off wont help because all youll see is the fat end of the adjuster screw.
All thats holding it in, is the stiction of the gasket.
On mine i had to put a little bit of bar in the open hole and tap it perpendicular. A little to one side a little to the other.
Only other thing i could suggest it warm it right up with a hot air gun or soak it it boiling water!!
Dont get it too hot i think that casing is mag alloy.
(explosive under the right conditions)
gray
#7 PostAuthor: gray » Sun May 17, 2009 8:55 pm
yeah , you won't be able to adjust the clutch with the whole sprocket cover off , that's just so you can remove the plate , once the plate's off then the sprocket cover has to go back on .
gray
gray
Steve Cooke
#8 PostAuthor: Steve Cooke » Sun May 17, 2009 9:30 pm
Push two old long M6 bolts back into the holes a wiggle up and down (on the bolts that is).
#9 PostAuthor: Rich » Mon May 18, 2009 5:53 pm
They usually stick to the gasket, put a 6mm bolt on the front hole and use it to lever the cover off. You need to remove it from the front as the sides are not square to the face of the cover.
Robw
#10 PostAuthor: Robw » Mon May 18, 2009 7:17 pm
Cheers guys I will give it ago tomorrow.
Rob
