I need a few spacers made up to mount things like rearsets and oil cooler bracket to my Lawson project. Has anyone got a lathe that can do these for me if I supply spec and drawings?
Obviously happy to part with beer vouchers........
Know anyone that can create one off parts?
martinz1000r
martinz1000r
Hi Col, thanks for the reply.
I need 2 spacers to hold a rearset away from the frame. I also need some spacers to hold an oil cooler at the right angle to the frame. This should be a case of 2 spacers on an angle for the top fitting and then 2 longer sleeves for the bottom fixings. If you can give me an email address I will send you exact drawings with angles and dimensions.
Cheers!
Martin
Cheers!
Martin
martinz1000r
