z1a carbs overhauling
should there be a rubber o ring on each airscew on the z1a model carbs ? There is no groove on the screw, either the original or the keyster replacements.
He who dies with the most toys wins .
- mick znone
Ita01, The 28 mm carbs on the Z1, Z1A & Z1B, although, as Mick says, they changed a little during the period, they had no rubber o-rings on the air-screws, they just had the small spring. These are the screws on the side of the carb, that are usually set to about 1-1/4 to 2 turns out.
- mick znone
- mick znone
it would seem so Pasc.
its that old saying again.... you can please some of the people some of the time but you cant please all of the people some of the people all of the time you are trying to please some of the time you are trying to please argh f.ck em anyway
