Key # 754
kawamick
Key # 754
#1 PostAuthor: kawamick » Thu Mar 12, 2009 10:50 am
Need for my Z1 key #754.
Thanks Mick
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Thu Mar 12, 2009 1:47 pm
MICK
Try Johnnys vintage motor cycles in the US,they list 754 key as available and cost is $15 +shipping.
Thats if no body on here can sort you with one.
Regards
Steve
floydsz1
#3 PostAuthor: floydsz1 » Fri Mar 13, 2009 8:41 pm
I got a blank from bernie at beezeees a couple of years ago, It looked just like the original. all i had to do was take it to my local key cutter with the old key. Should be a link to beezeees somewhere on here
kawamick
#4 PostAuthor: kawamick » Sat Mar 14, 2009 1:47 pm
Yes, thanks i know beezeees.
Will try this.
Mick
LTD Project
#5 PostAuthor: LTD Project » Wed Mar 18, 2009 11:33 am
How can you tell what key number you have, ther is nothing on my key and nothing on the ignition switch that I can see?
Am I missing something where it is shown?
Otherwise I will need some blanks to cut off my only key.....
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Wed Mar 18, 2009 12:56 pm
LTD
The number should also be on the seat lock and steering lock.
Regards
Steve
gbh
#7 PostAuthor: gbh » Wed Mar 18, 2009 1:26 pm
wilsonsjw11 wrote:LTD
Regards
Steve
You're right about the numbers being on the seat lock and steering lock. However I would check the ignition switch in case anyone has changed one or the other at some point. You should find the number stamped along the side of the barrel, they're not terribly hard to remove.
