Wanted - brass intake pipe for 73 Fuel Tap
MaineKZ
#1 PostAuthor: MaineKZ » Sun Jan 04, 2009 8:50 am
Anyone got a spare intake pipe by any chance? I think the pipe is the same for all zeds 73-75
Failing that, anyone managed to find a supplier who stocks this gauge of pipe?
Failing that, anyone got a complete tap for sale with pipe intact?
ta
Steve Cooke
#2 PostAuthor: Steve Cooke » Sun Jan 04, 2009 5:59 pm
What size is the pipe your after as i've got a couple of ropey taps with two different sized pipes.
MaineKZ
#3 PostAuthor: MaineKZ » Sun Jan 04, 2009 9:43 pm
thanks Steve but I've found a suitable pipe from a model engineer supplier:
http://www.maccmodels.co.uk/kandsbrassmetric.htm
size is 6mm O/D, 0.5mm wall thickness
Steve Cooke
#4 PostAuthor: Steve Cooke » Sun Jan 04, 2009 10:47 pm
No problem, one of these is correct so if you do have any problem let me know.
MaineKZ
#5 PostAuthor: MaineKZ » Mon Jan 05, 2009 12:28 pm
Will do
Just out of interest, what year is your spare tap from?
Just wondering whether it has the same black plastic 'selector' sleeve inside like the 73? These sleeves don't seem to be available and mine is not perfect. Have you dismantled yours by any chance?
Steve Cooke
#6 PostAuthor: Steve Cooke » Mon Jan 05, 2009 6:27 pm
Not sure what it's off it has the twin outlets at right angles to each other and the sleeve is beige, it was off an A4 but i've also seen them with the parallel outlets.
#7 PostAuthor: chrisu » Mon Jan 05, 2009 6:41 pm
certainly sounds like an A4 one to me...........
GregZ
#8 PostAuthor: GregZ » Tue Jan 06, 2009 6:47 pm
MaineKZ wrote:Will do
Z1 fuel tap rubber inserts available here.bottom of page..
http://www.americanclassix.com/kawa_rubber.html
Z1
1965 Corvette
MaineKZ
#9 PostAuthor: MaineKZ » Tue Jan 06, 2009 9:52 pm
Nice one Greg - thanks for this. Have emailed them to check they'll ship to UK.
If not could I maybe sort one out via you?
GregZ
#10 PostAuthor: GregZ » Fri Jan 09, 2009 11:28 pm
If you need help with overseas shipping you can have it mail to me and I will send over to you
cheers
gregz
Z1
1965 Corvette
