widest section rear tyre
steve rees
#1 PostAuthor: steve rees » Sat Oct 11, 2008 9:39 pm
Guys,
Some advice please-------------
what is the widest section rear tyre that you can safely use on a '78 Z1000A2
to fit on a seven spoke Z1000 alloy wheel.
Thanks in advance
reagrds
Steve Rees
Reecy m21
FER
Auld Heedyun
#2 PostAuthor: FER » Sat Oct 11, 2008 10:01 pm
130 is the widest on a standard rim . Even this will get pulled a bit as it should really be on a wider rim . Avon do a 130/650VB18 which is designed for a 2.15 rim but it is a race tyre and they don't last too long .
fer
#3 PostAuthor: chrisNI » Sat Oct 11, 2008 11:33 pm
With a standard front tyre it'll probably steer best with a decent rear of the proper size ie. 120. They do look skinny though.
Iain marshall
#4 PostAuthor: Iain marshall » Sat Oct 11, 2008 11:38 pm
120/90 18 BT 45 works fine for me Steve
