How much fork oil - How many ml oil in forks
- london calling
For a 1982 Z1000LTD-K the fork oil spec is 10w20 oil,with about 320cc when changing oil and 351cc +/- 4cc after disassembly and completely dry.Front fork air pressure 0.5kg/cm2.
Obviously adding more oil than the figures above will increase the air pressure in the fork,so only slight increases are advised.
Due to the age of the bike also check your free spring lengths.Short spring 130.5mm,Long spring 470mm.
The genuine Kawasaki Z1000/Z1100(GPZ)workshop manual has all the factory settings and specs for your bike.
