Z1b seat. Lock or Lever ?
Pasc
#1 PostAuthor: Pasc » Thu Aug 21, 2008 3:44 pm
I keep seeing seat locks and keys for sale for a z1b but mine has not got a lock just a lever pointing 3 oclockish and rotates to about 5 or 6 oclock to unlock the seat. Can anyone shed any accurate information on this ?
floydsz1
#2 PostAuthor: floydsz1 » Thu Aug 21, 2008 6:04 pm
The lock is a seperate thing and screws up (with 2 screws) just underneath the lever. The lever will work ok but you cant lock it , er obviously ,without it.. you might just be able to see the 2 screw holes behind the hole in your side panel, were the key would fit.
phil churchett
Re: Z1b seat. Lock or Lever ?
#3 PostAuthor: phil churchett » Thu Aug 21, 2008 6:16 pm
Pasc wrote:I keep seeing seat locks and keys for sale for a z1b but mine has not got a lock just a lever pointing 3 oclockish and rotates to about 5 or 6 oclock to unlock the seat. Can anyone shed any accurate information on this ?
Pasc, you are not that far from me, if you want to take look at mine.
floydsz1
#4 PostAuthor: floydsz1 » Thu Aug 21, 2008 6:22 pm
Forgot to say, the screws actualy screw in a downward direction pulling the lock mechanism upwards, if that makes sense,
Pasc
#5 PostAuthor: Pasc » Thu Aug 21, 2008 6:50 pm
Thanks for the info Floyd.
Phil, thanks mate. I'd like to pop over sometime and take a gander. The bike is nearing the front of the queue for a full restoration. Most of it is there (well all the important bits anyway). But I am going to need to research things like fastener finishes etc. I'll drop you a pm over the next few weeks and arrange something.
ps Phil, have you been getting over to Bassetts Pole this summer ? Not been this year. Weather and diy seem to have been ganging up on me.
GEZ635
#6 PostAuthor: GEZ635 » Thu Aug 21, 2008 7:02 pm
Pasc, if you want to pop round I have 2 fully restored z1's in my kitchen and you can look at the seat locks. I can also give you all my contacts for zinc plating etc. I am just off thornbridge avenuce.
Gerry
Gez
Pasc
#7 PostAuthor: Pasc » Thu Aug 21, 2008 7:32 pm
Will do Gez,. Thanks very much. I still need to collect the coil from you. Did you manage to free up the z1b cases we spoke about ?
I'll give you a bell over the next few days.
rickman CRR
#8 PostAuthor: rickman CRR » Fri Aug 22, 2008 12:01 pm
I think it was the Z900 A4 (1976) and later models that had a seat locks fitted.
