Bead Blasting
Bead Blasting
Picked up the head and barrels at the weekend; amongst other things they have been bead blasted. I am a bit concerned that although the gasket surface on the head is flat and smooth, on the barrels the gasket surface has been bead blasted and is not therefor smooth but rough, is this Ok will the gasket still seal ok? Is this normal?
- RALPHARAMA
It will probably seal better, though I must admit I would have masked mating faces etc.
Ralph Ferrand
