Smallest battery to run a Zed with no electric start.
Gus
#1 PostAuthor: Gus » Mon Jul 14, 2008 4:03 pm
What is the smallest amperage battery I can use to run a Zed with no electric start and no lights?
The charging system will still be in place.
What do total loss systems use?
Gus
"Set the GRINDER on it"
Big Glenn
#2 PostAuthor: Big Glenn » Tue Jul 15, 2008 4:41 pm
Is it running on pionts, or have you converted to electronic ignition? and how small do you need to go?
Gus
#3 PostAuthor: Gus » Tue Jul 15, 2008 5:11 pm
Hi Big Glenn.
It's running on points at the moment.
I will run a brake light and the horn for the MOT.
I will retain the charging system and it has already been converted to a rec/reg pack.
Hope this helps.
Gus
#4 PostAuthor: Pigford » Tue Jul 15, 2008 5:20 pm
A day time MOT doesn't even need a brake light :shock: although common sense says best to have one :wink:
Gus
#5 PostAuthor: Gus » Tue Jul 15, 2008 5:35 pm
Exactly my thinking Mr. Pigford.
FOZ1A
#6 PostAuthor: FOZ1A » Tue Jul 15, 2008 6:12 pm
I was thinking of doing something similar on the rickman and my electrical wizard around 8 amps should be enough,and use a gel battery cause you can mount them anywhere!!
Foz
drink feck arse girls
Big Glenn
#7 PostAuthor: Big Glenn » Tue Jul 15, 2008 6:32 pm
I reckon 8 amps would be more than enough, with only the ignition system to run, and the charging system still hooked up. Have a look at batteries for 125cc sports bikes.
Gus
#8 PostAuthor: Gus » Tue Jul 15, 2008 7:43 pm
I would have thought the charging circuit would put out enough to run the bike.
Does anybody have any output figures?
Maybe a small battery would help stabilise the system using the sense wire from the rec/reg unit but I'm only guessing.
Who built the Gardner Moriwaki replica, doesn't he run a total loss system using a battery from a model shop or something similar?
FER
Auld Heedyun
#9 PostAuthor: FER » Tue Jul 15, 2008 8:03 pm
Boyer do a power box which doesn't need a battery . Reg' and rect' built in . Got one on my lawson and it works ok .
fer
Gus
#10 PostAuthor: Gus » Tue Jul 15, 2008 8:48 pm
FER wrote:Boyer do a power box which doesn't need a battery . Reg' and rect' built in . Got one on my lawson and it works ok .
fer
Do you run the Lawson without a battery fitted Fer?
How much are they?
I see on the Boyer website they mention a capacitor in the power box.
That is sort of what I meant about using a small battery to stabilise the system.
I'll try and give them a ring tomorrow.
Gus
#11 PostAuthor: Gus » Wed Jul 16, 2008 5:11 pm
The technical Guy at Boyer doesn't think that kicking the bike over will spin the alternator fast enough to generate enough power to fire the engine( I think he said around 300rpm).
Although a push start does work for race bikes.
He thinks maybe a 3Amp battery with their Power Box might just do the trick.
So I might as well just try a small Amperage battery with what I've got.
The Power Boxes are £78 delivered.
