Returnof the Z - project
eastlondon
#16 PostAuthor: eastlondon » Fri Jun 27, 2008 9:08 am
The wheels look o.k. 19inch front and 18 inch rear. If the brake disc has six mounting bolts then it is a z1 front wheel. The A4 has 4 bolts. The rear wheel looks like it has had an alloy rim fitted which is a bonus.
Keep the Z1 front end on as it highlights the bikes pedigree. You just need to bear in mind that should you need any replacement parts, you will need to order Z1 parts and not A4.
keep up the good work. Pics of my A4 will be posted over the weekend hopefully.
Raf
