compression deppression
Hi fellas, after rebuilding the motor on the Z1B we noticed a bit of smoke out the exhaust on a recent run. The bike has only 200 miles on the engine, it had the heads recond. new rings, but the bore was only honed. I did a compression test and got a reading of only 90 PSI per cylinder, squirt of oil made no difference. The local mech. says it still needs time to bed in. What do you think??
