Height Level with top nut on light and frame (light points down).
Is a short guard more of a rightangle?, mine seems to be flared out.
Seems to be a gap when viewed side on, could it be bent?..
On a happier note..........
GEZ635 wrote:I agree...wrong bracket..If you are looking to put it back to standard I may be able to help with long rear mudguard.
steve bowdler wrote:Hi again have tried to get a photo of my light bracket beu with the tail unit on can not really get a good photo,you are more than welcome to call up to my house for a look,or i will be taxing my bike this weekend and I will call down,I shall pm you my mobile .
steve bowdler wrote:Sorry to be the bearer of bad news my mate used Bont tyres he had to leave the wheel there went back next day to collect as arranged he had'nt touched it think he ended up waiting three days in the end,Try M&P saturday morning first come first serverd
Thezedsintheshed wrote:Ahh looks as if I have finally sorted the photo posting bit !
I checked the "raised" section of the mudgaurd where it bolts to the frame tube and it is 5".
The mudgaurd in the photo is an original US spec one and the light unit has never been removed from it so if the light bracket on your mudgaurd doesnt match up with this one then that could well be the problem .
as per PM you are welcome to borrow the light bracket as a pattern to get one to match up.
If you are looking for a MOT test for Saturday then give Fairfield Garage in Port talbot a ring, the guy there who does the testing is fair and he knows his older type bikes. same sort of pass rate as Pritchards
